mickoz said:
Hi,
Im looking at buying a 02 250exc. Does this year have any problems.
Does the 02 have the same frame as the 03 and 04 models. Is the motor the same motor as the newer models. Ive heard the older KTM's have the kokusan ignition and its not reliable, Does the 02 have this ignition.
Any info would be much appreciated.
Cheers.
As far as the exc, 02 and 03 have the same frame, 04 has a lighter frame and motor, 05 was an upgrade also. Th ignition is fine, no worryies. I would say buy as new as you can afford. In 04 they lost a bunch of weight. I would get an 04 or newer, butthe older ones are great machines also. Check the FAQ at the top of this forum.
