Got Jeff Slavens high altitude needle in today and all i can say is WOW!!!
I live @ 5K and ride from there up to 10K. Ive always had issues with the bottom 1/8 to 1/4 being a little blubery. Since i ride most of the time in this throttle position, it just drove me nuts.
Ive tried several different combinations to rid myself of the low end fat spot to no avail. When i did get it to go away, it would jack the rest of my jetting.
So, i bought and installed Jeff's needle today and it made a huge difference.... You crack the throttle now and it is no problem lifting the tire over and obsticle. Needless to say, i am impressed and i just wanted to share this with the community.
I am sure you can use some other needle or combination to get the same results, but i took the easy route.... Jeff is really knowledgable when it comes to the 300 and the 20 bucks for the needle was definately worth it.
