Stupid question
10 replies to this topic
  • SpyridonMexas
Posted May 14, 2009 - 11:22 PM
Do i have to remove the tank to change the spark plug on a YZ? and where is it located?:doh:
  • husqy360
Posted May 14, 2009 - 11:33 PM
yes need to remove tank. plug located in the middle right on top of the engine.
you will probebly need a swivel wranch. depend on year.
  • gdbarr1976
Posted May 15, 2009 - 06:11 AM
I will have to disagree. You do not have to remove the tank. It is tite but doable. You will need the spark plug wrench that came with the motor. It swivels and a 14mm wrench. Actually getting the plug out is easy. Getting the spark plug cap off is the trick. But it can be done.
  • spark250
Posted May 15, 2009 - 06:15 AM
I think it's a grand total of 4 bolts to get the tank off and make your life a lot easier!
  • Wiz636
Posted May 15, 2009 - 07:36 AM
I think it's a grand total of 4 bolts to get the tank off...
Sure about that?
But I agree that it is easier to just remove the tank than try to get the plug cap off and on with the tank on.
  • spark250
Posted May 15, 2009 - 07:43 AM
Sure about that?
There was a hint of sarcasm there...:doh:
  • gdbarr1976
Posted May 15, 2009 - 08:01 AM
I seem to have more trouble getting those screws back in holding the shrouds to the radiator then getting the plug out.
This how you do it.
1. Get a beer of your choice and a stool.
2. Turn on some good music
3. Call your buddy that has the same bike and have him/her come over and do it for you.
4. Make sure you offer them a beer.
5. Figure out why you are changing your plug in the first place. My experience has been if I am changing a plug then there is another problem I need to fix and it is usually tite valves.
Posted May 15, 2009 - 08:16 AM
Especially when using an oversize tank. That's why I pull the shrouds off the tank instead. One of these days, I'm going to run a stud and an acorn nut in the front shroud bolt hole and make my life simpler.
  • SpyridonMexas
Posted May 15, 2009 - 09:26 PM
Getting the spark plug cap off is really tricky...any suggestions?
  • husqy360
Posted May 15, 2009 - 10:15 PM
just pull it as hard as you can.
1 hand from each side.
carfull on wires.
  • mikedabike
Posted May 16, 2009 - 01:50 AM
Unplug it from the wires. I comes right out then.
  • Hot  113 replies
  • Hot  50 replies
  • On January 15, 2017
