XR6 Shock Removal
2 replies to this topic
  • Terrain Rider 4z
Posted March 09, 2003 - 04:54 PM
I am planning on having my rear shock serviced by the local suspension guy. To get the $75 rate I need to remove the shock, which I have yet to do. Is this a difficult procedure? Are there any tips or tricks I need to know beforehand? I prefer to try these things myself as opposed to having a shop do all of the work. Please help if you have any pointers.
Thanks in advance
Ryan
  • Matt96xr6
Posted March 09, 2003 - 07:47 PM
It is pretty easy.
First get the bike off the wheels. use a bucket or something under it and make sure it is stable.
Remove the side panels and the seat.
Now you have access to the top shock bolt. Loosen and remove the nut. Leave the bolt in there.
now look at the lower end of the shock in the linkage. Remove the nut and bolt there. You may find it easier to get to the lower bolt by taking out the top shock bolt and then adjust the rear wheel height with a jack or tiedowns from the swingarm around the top of the airbox frame there.
Once the shock us unbolted, you can wiggle it out. If you want more room, you can always remove the airbox and that makes things even easier.
You should consider getting a Clymers manual for the bike. Has a ton of things for maintaining and servicing the bike you will use.
  • Terrain Rider 4z
Posted March 10, 2003 - 04:42 PM
Thanks Matt. I do have the Clymer manual, but was looking for an easier way. The manual states the airbox needs to be removed, but if I can slide it out the bottom I will go that route. Is this the way everyone else does it?
Thanks,
Ryan
Honda XR650L 2017
  • 0 reviews
  • 3 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  186 replies
