Adding a another 35watt bulb? Help
8 replies to this topic
  • phynx
Posted May 12, 2009 - 03:33 PM
Hey guys! Will I be okay if I add another 35watt bulb (mini fog light) on to my battery while riding my 03' wr450? I want to mount a light to my helmet. Everything is stock (stator). Will I harm or kill anything?
Or, will I have to modify anything?
Thanks TT members!:excuseme:
  • Dube2
Posted May 12, 2009 - 06:57 PM
I'm pretty sure it will slowly discharge the battery. Stator wont keep up and only good for the stock head/tail light and not much else. just my opinion. Baja Designs makes a stator up-grade that will give you more watts.
  • phynx
Posted May 12, 2009 - 07:25 PM
Do you have an idea of what the stock out-put is?
  • William1
Posted May 13, 2009 - 09:19 AM
All depends on what year WR you have. Stock stator on the current breed is a split 65/55 watt unit, with 55 staying as AC for the headlight and 65 being rectified to DC for the battery, CDI and tail light.
  • phynx
Posted May 13, 2009 - 01:33 PM
William, I have a 2003 model. Is there a difference? The head lamp bulb is stock also. Is Ricky stator a requirement here to add second bulb (35-55 watts more)? Thank you for the help.
  • William1
Posted May 13, 2009 - 04:21 PM
No, to make it possible to add an additional draw of 35 watts, you are in for some re-wiring.
You need to do the BD stator mod, easy and cheap to do, takes me about 30 minutes, working slow. It combines both coils and outputs a single 110 watt. Then you replace teh reg./rect with a BD one that has the capacity to deal with the greater output. Then you need to change the headlight power to come from the battery. Several ways to do this.
  • TLRam1
Posted May 15, 2009 - 08:12 AM
Thanks William, do you know the output for the 04 WR450, is it the 65/55 also?
  • William1
Posted May 15, 2009 - 08:28 AM
Yup, changed in 03, prior models had less and a slightly different setup, I think. BD probably has the definitive answer on the outputs over the years and what you can expect.
  • Birdy426
Posted May 15, 2009 - 09:42 PM
00-02 426's had 135 watts of all AC, and 98-99 400's had 90 watts of all AC.
