2010 KTM model info. Deleted models and upgrades/changes
111 replies to this topic
  • Chazmanian
Posted 12 May 2009 - 12:50 PM
Courtesy of mark from Shoals outdoor power sports!!!2010
Deleted Models:foul:
All ATV's
50 SX Junior
65 XC
85 SX
125 SX
85 XC
105 XC
200 XC
250 XCF
450 XCF
505 XCF
2010:ride:
» 150 XC
» 250 XC
» 300 XC
» 105 SX
» 150 SX
» 250 SX
» 250 SX-F
» 450 SX-F
CHASSIS - SX/XC:thumbsup:
» Modified Air Box With New Design TwinAir Filter
Improved air filter protection
· New shape in the front to reduce dirt or water collection and a slight wall in the back to avoid water coming into the filter
New TwinAir Filter designed for the new airbox
» New Front Brake Pads - Toyo B153
· Combined with last years new SX caliper that provide awesome performance with a more progressive feel
» New Renthal Hand Grips
» New Graphics
» Entirely New KTM Patented Triple Clamp Design
Off-set is now 22mm fixed (2009 - 20 mm)
· Twin screw design on lower triple clamp instead of triple screw
· Designed for improved flex characteristics and optimal handling
» Revalved Suspension Settings
· Forks have a new seal and bushing to reduce sliding friction
· Combined with the new triple clamp, the suspension provides optimal handling and stability
2010
250's
Two-Stroke SX & XC
� 250 SX
�Reinforced cylinder head for durability
� 250 XC
� New XC specific combustion chamber - not an SX
� New XC ignition curve and carb setting - matches new cylinder head design
� Specific power band for XC riding - not as aggressive as SX but increased from XC-W
� New Exhaust Pipes for All Two-strokes
� Wall thickness increased from 0.88mm ��1.00mm -More resistant against damage
� New Translucent Fuel Tank for XC Models
� Easy to check fuel level
� New Radiator Cap on Two-Strokes - 1.8 bar (old 1.4 bar)
� Better heat stability
2010
Mini's
» 50 SX Mini
» 50 SX
» 65 SX
50 SX Mini and 50 SX
» New ignition cover
Improved sealing
» New inner clutch hub
Improved reliability
» New gearbox shaft
» New water pump impeller
Improved cooling and engine efficiency
65 SX
» New engine case design
Improved sealing
2010
450 SX-F
» New Frame Design - Frame Is Welded To The Steering Head 10mm Lower Than 2009
· Rotates the frame and engine forward slightly - Lowers the tank and seating position
· Improves the weight balance, provides less deflection on the front end, better control of front wheel, lighter feeling
» New 5-speed transmission
· Close-ratio 5-speed provides broader range for varying conditions
» New Titanium Header and KTM HPRS (Header Pipe Resonator System)
·Lightweight, reduced noise level
» High-end Machined Front and Rear SXS Brake Calipers
·Minimal weight, maximum brake performance, added value
» Rear Shock Shortened by 4mm
·Works in conjunction with the new frame design
» New Carb Setting
·Improved rideablity and low-end power delivery
2010
» 150 SX & XC
- New Frame With a Steeper Steering Head (0.5°)
· Easier cornering - Better feel for front end
· Triple clamp off-set is now 22mm fixed (2009 - 20 mm)
» 150 SX & XC
· Reinforced 1st gear for durability
2010:smirk:
» 200 XC-W
» 250 XC-W
» 300 XC-W
» 400 XC-W
» 450 XC-W Six Days Edition
» 530 XC-W Six Days Edition
» 450 EXC
» 530 EXC2010
» New Lighter EXCEL rims
CHASSIS - All Models XC-W & EXC
» New front Brembo brake caliper (like 2009 SX), new TOYO B153 brake pads
· Floating 2-piston caliper with new brake master cylinder and new TOYO pads
· Improved brake performance, less lever force, more progressive feel
· Improved air filter protection
· New TwinAir Filter designed for the new airbox
» New suspension valving, PDS with new needle design
· Similar needle as SX/XC from 2009 - provides damping slightly earlier for more progressive feel through the stroke
» New DID 520 VT2 X-ring chain instead of Regina
· Improved durability, less friction
  • mototack
Posted 12 May 2009 - 01:31 PM
Great intel, Thanks' :thumbsup:
Dropping the 125SX makes sense with the current AMA rules. Glad to hear their improving 1st gear in the 150SX my son smoked first gear within .5 hrs of new destroyed the entire transmission luckily they covered it under warranty. Still no EFI for the 450’s???
  • Magic-Man-150
Posted 12 May 2009 - 01:32 PM
yea, this sucks. why would they get rid of the 125... thats retarded. and the 85. and freaking sewage tanks on the xc's? this is bullcrap. i was like 150xc, exactly what i wanted minus the ugly tank. i guess i will be getting an 09 150sx.
  • Magic-Man-150
Posted 12 May 2009 - 01:35 PM
one last thing... i just wanted to tell everyone I WAS RIGHT ABOUT THE 200xc going away!! im bummed for that too, i was also considering that bike.
  • Drinkn_Buddy
Posted 12 May 2009 - 01:44 PM
Finally, they address the crappy air boxes!!! Can't wait to see how much they will want for one.
  • Wrfrk
Posted 12 May 2009 - 01:50 PM
I'd like to see some pricing, will have puke bucket handy as to avoid cleanup from mess.......
  • llamaface
Posted 12 May 2009 - 01:52 PM
pricing was reported to be about the same as 2009.
  • dirtbiker82004
Posted 12 May 2009 - 03:57 PM
KTM better not be headed where Honda went with the no two strokes thing. seems like they are getting rid of a fair amount of them this year. that bums me out that they got rid of the 200xc!
  • Magic-Man-150
Posted 12 May 2009 - 04:06 PM
i know, they cut ALLOT of bikes. how can they have no 85? i just dont understand that.they will be all gone by 2012, maybe even 2011. i bet. first they are gonna release a thumper alternative (i.e. 150sxf) because there is no minis. they are gonna be the first to actually make one.
  • mtman
Posted 12 May 2009 - 04:44 PM
he never mentioned that the 85SX was going away, or that it was staying so I bet it stays. And thank god they got rid of the 200, it was the worst displacement ever. Like bringing a knife to a gun fight, and it took the worst qualities of a 125 and 250 and mixed them into one ball of poo.
  • 657pinkKTM
Posted 12 May 2009 - 04:57 PM
mtman, have you ever ridden a KTM 200? They are incredible bikes, my dad has one and I cannot find a downside. Rather, it is all the QUALITIES of the 125 and the 250 mixed together. I've wanted one for the longest time. He is very happy with his and the power is straight through with lots of torque everywhere. Smooth powerband as well.
I'm sure all the '10 bikes are sick but I could not be happier with my 144. It's been my dream bike for so long. I haven't nearly put the hours on it, my guess is under 10, but we're 2 peas in a pod I suppose you could say. :thumbsup:
Too bad about the chains as well, IMO Regina and KTM go hand in hand.
  • Magic-Man-150
Posted 12 May 2009 - 04:59 PM
yea i thought the 200 was pretty neat, they still have the xc-w but screw that. whatever, i dont need a 200xc anymore now there is the 150xc! (flucking sewage tank...)
  • Magic-Man-150
Posted 12 May 2009 - 05:00 PM
Deleted Models
All ATV's
50 SX Junior
65 XC
85 SX
125 SX
85 XC
105 XC
200 XC
250 XCF
450 XCF
505 XCF
  • Zak Smith
Posted 12 May 2009 - 05:39 PM
The XCW setup is probably better for the intended niche of the 200 anyway.
What I want to know is: can we retrofit the new airboxes to 08/09 bikes?
  • love2strokes
Posted 12 May 2009 - 06:12 PM
http://www.totalmoto...0models-KTM.htm
check out that website it says some different stuff including some street 2 stroke models---hard to tell if its right though, I have to think Shoals motorsports would have better info. than this website but I just thought I'd post this up...
  • Chazmanian
Posted 12 May 2009 - 08:39 PM
That website is garbage Bro.
I simply copied and pasted info that came direct from KTM to Shoals to me.
Here is the 2010 Brochure:http://www.ktm-parts...der%20Guide.pdf
I did get a laugh outta reading 2010 300 XC-W "Street" though:p
Those derned Euro folks and the Aussies get street legal 300's...Not us!!
Tell ya what. KTM releases a 2010 street legal 300 XC-W in our North American US market? I will Pay-Pal you $1000.00 Cash money on the spot.
The website link you gave is madness. The XC-F 250/450/505 models are done. 65/85/105 and 200 XC's are toast. 125 SX's are ancient history.There isnt gonna be any street legal smokers. ATV's are history.Not in our market. Not in 2010.
The writing was on the wall when our economy crashed. Most those models are simply built for the US market. They havent sold the XC line of thumpers in Europe for a long while if ever or the smokers XC's. We are essentially being offered the same menu as the Euro or World market rather than having the US market specific models along with all the others.
  • Aido_DRZ
Posted 12 May 2009 - 10:36 PM
2010:ride:
» 150 XC
» 250 XC
» 300 XC
» 105 SX
» 150 SX
» 250 SX
» 250 SX-F
» 450 SX-F
I don't see any major drama's here really, losing the 200XC is a bit of a shame but they are still making all the best 2T and 4T models that are worth riding imo.
Btw Kiwi i actually think changing to the DID chain is a good thing..DID make a quality chain. :thumbsup:
  • PumkinFest
Posted 13 May 2009 - 01:56 AM
125, 200, 250, 300 EXC have always been street legal here :ride:
  • Chazmanian
Posted 13 May 2009 - 04:36 AM
In Colorado I simply bought the Enduro Eng Euro light kit, a cheap mirror, a policy through progressive and Viola!
I too have a street legal 3-Hunny.
Now our state law is getting funky and Californicated. "DirtBikes" are getting harder to tag if they are built after a certain date Yada-Yada...
Looks like I may be riding my tagged 300 for years and years!!
  • gmoss
Posted 13 May 2009 - 04:46 AM
Magic Man, it doesn't say anything about the clear tank on the 150, just the 250. Don't get all wadded up about it. I still think you are taking a chance with the 150, but it's your money. You should ride a 200.
I hate to see the 200XC go away as well. BUT, if KTM puts the TC forks on the W, you got dern near an XC anyway. They share very similar trannies.
mtman, it's ashamed that you feel that way about the 200. I suspect you really haven't spent any time on one, or ridden it where it shines.
