100LL AV fuel
5 replies to this topic
  • FinchFan194
Posted May 11, 2009 - 02:27 PM
I am not looking for any performance increases, but I was told that running 100LL will your motor last longer and keep it from grenading.
My 04 has been rebuilt but she isn't getting any newer just want the bike to make it through this season without blowing up. I am not worried about it when I ride trails. Is the 100LL a good option to help my bike when riding on tracks or lets say if I make a dune trip?????
It seems the quality of our 92 pump gas isn't what it used to be because it all has 10% methynol or etheynol or whatever that stuff is.
Can anyone help me out??
Posted May 11, 2009 - 03:11 PM
Aviation fuel is a source of popular folklore and myth. The fact is that it will do neither of the things you mention, it will probably increase the combustion chamber deposits in your engine, and is formulated entirely wrong for a high rpm engine with a short intake such as yours.
AvGas is blended for engine that operate at continuous low rpm's at high altitude, not for engines that require immediate response to constantly changing throttle and load conditions.
Furthermore, the lead deposits that will form on the valve faces of the exhaust valves may have a tendency to degrade the TiN coating, and actually shorten valve life.
Don't use it. Pump gas is cheaper, more available, and while not the optimum fuel, it is a much better blend for your engine than any AvGas, even with 10% ethyl/methyl alcohol.
  • davidl9999
Posted May 11, 2009 - 03:13 PM
+1 :excuseme:
Pump-grade gasoline has up to 10% Ethanol in it. It does rob some power over 100% gas, but if everyone else racing is using it, you'll do fine. The Ethanol component will actually lower cylinder pressure vs. 100% gas, so that's actually good for longevity.
  • FinchFan194
Posted May 11, 2009 - 03:15 PM
Awesome thanks guys for saving me from making a mistake.
  • Watige420
Posted May 15, 2009 - 11:46 PM
+1 ^^^
  • yz007f
Posted May 16, 2009 - 07:27 AM
Ethanol also runs leaner... And don't be surprised if there is more than 10% ethanol in your fuel. I have seen up to 30%!!!!!!! which is retarded if you ask me. I will only run race gas in my bike now...
  • 0 replies
