white bros xcs and e series
3 replies to this topic
  • Pete Thomo
Posted May 11, 2009 - 12:08 PM
Can any one help with my problem i have been told by a dealer in the uk that the white bros xcs and e series end cans will not fit the header of my 08 wr450 is this true or do you lads just fit a sleeve to the smaller header and tighten up to it some pics of your work would be most helpful
thanks Thomo
  • beezer
Posted May 11, 2009 - 12:16 PM
White Brothers went out of business. Vance & Hines bought what was left of them. Which is a shame, they made great pipes.
The WR and YZ have different diameter head pipes. Just get a YZ headpipe on eBay.
  • Pete Thomo
Posted May 11, 2009 - 03:00 PM
Is there a shim or filler that will fill the gap ? how much gap? the pipe was ment for a wr450 not a yz450 are the US wr bigger bore?
thanks for your speedy reply
  • davidl9999
Posted May 11, 2009 - 03:08 PM
If the pipe was made to fit the WR header, you would not be asking this question. The cans and midpipe are made to fit the YZ header.
I had a similar issue fitting a TwoBros can and midpipe to a WR header. I gave up on kludging it together and just bought the matching TwoBros YZ header.
You can do a few things here (imo):
1) Get a YZ header from eBay. They're pretty cheap.
2) Get a YZ White Bros header from eBay or ask around the forums if anyone has one.
3) Other 3rd-party YZ slip-on headers will probably fit as well. Afaik, FMF Power Bomb and Mega Bomb headers will fit other MFR's midpipes. IDK for sure.
4) Keep the WR header, cut the carbon o-ring to fit, and clamp the midpipe to the WR header over the o-ring. Some red RTV may be needed if the joint leaks.
