how hot does a radiator get???
6 replies to this topic
  • crazymxrider_93
Posted 11 May 2009 - 03:27 AM
sorry its probably a stupid question, but i need to know how hot my radiator gets because i need to put a little JB weld on it because its somewhat corroded on the bottom. it doesnt leak, but i just want to be safe. :excuseme:
  • no1clyde
Posted 11 May 2009 - 04:19 AM
Well water boils at 212 and with a pressure cap that may be 230 or so so that would be about the hottest it should get. I have used JB type stuff to "fix" radiators before with good luck.
Ed
  • alex211
Posted 11 May 2009 - 05:08 AM
I used JB weld to fix my rad before. Make sure the metel is CLEAN, JB weld will not stick to dirty metal.
  • cxcmoto
Posted 11 May 2009 - 06:28 AM
Most radiator caps are rated at 1.1 bar or 15psi.
That would mean it could reach 250F before boiling over.
A heavy duty cap would be 1.6 bar or 20 psi. == 264F
JB weld is fine up to 500, so no worries there.
+1 for the cleaning -- I suggest brake cleaner because its easy to get and does not leave a residue. - JB weld says acetone, lacquer thinner, and not alcohol.
http://www.jbweld.net/faq.php#faq006
REF:
http://www.engineeri...ater-d_926.html
remember to add atmospheric pressure when using the charts.
  • AtomicXRer
Posted 11 May 2009 - 06:41 AM
The boiling point of 50/50 mix of ethylene glycol and water is 265F....so I would think your radiator wouldn't get hotter than this...IMO
I have used JB weld on the cylinder head by the KIPS valveand have had no problems.
  • Polar_Bus
Posted 11 May 2009 - 08:05 AM
Under normal operating conditions a motocross cooling system runs about 130-150F. MX bikes don't use a thermostat so coolant temps can be all over the place, depending on many variables such as ambient temps, jetting, piston top end condition... and so on..
  • crazymxrider_93
Posted 12 May 2009 - 06:54 AM
ok thanks guys :excuseme:
