YZ450F Not Runing too good after Rebuild?
7 replies to this topic
  • martis_d
Posted May 10, 2009 - 06:06 AM
Not running too good after top end rebuild and new cam chain. i put a cp piston in it and upped the compression a little and done all the valves after finally putting it back together it will not kick start, had to push start it down a hill(not fun)then i blead the oil line to the head and after that it ran for not even 5 minutes, it then snuffed after i tried to crack throttle. after running it still would not kick start(***), driving me nutz. any help please ppl.
cheers
Mad Dog
  • TIG88
Posted May 10, 2009 - 07:58 AM
Double check timing and valve clearence.
  • knuckleduster271
Posted May 10, 2009 - 08:02 AM
Those 5 valve motors, two of the valves look alike but are a hair different in size, you may have gotten these mixed up if you took the valves out
  • martis_d
Posted May 11, 2009 - 04:23 AM
It Ran, the valves there is no way they got mixed up at all.
will be going through a few things starting with the basics carby service, new spark plug then dig deeper and go through the timing. i was so sure with the cam chain timing but will be tripple checking it again.
  • FEAROFRUNNER
Posted May 11, 2009 - 06:27 AM
I just did a rebuild on my 426 with pretty much everything you descriped minus the hi-comp pistion. It was hard to get started also, not hard kicking just didn't want to fire and was that way untill i got about 5 hrs on the motor. If I understand right, when a brand new motor is being broke in, the compression isn't the greatest untill those rings seat. If everything sounded ok when you did get it started then i would say try it again.
  • spark250
Posted May 11, 2009 - 06:34 AM
As mentioned above I think you need to check your timing and valve clearances.
  • TIG88
Posted May 11, 2009 - 12:39 PM
Your rings will seat well within the first several minutes of running. This is assuming your running it hard and under a load. Deceleration is key here too.
My bike was never hard to start after a rebuild.
  • martis_d
Posted May 17, 2009 - 10:15 PM
I looked into it and found the cam timing out by one tooth on both cams, i fixed that then broke the plastic and of the hot start choke cable going into the carb and lost the spring......gr.. orded new ones and have to wait to fire it up.
  • On January 15, 2017
  • Hot  28 replies
  • Hot  36 replies
  • Hot  38 replies
