Quick oil ?
6 replies to this topic
  • pbviking
Posted May 09, 2009 - 06:04 PM
Hey guys,
i just want to make sure.....
I going to put in some Semi-Synthetic into the 450 until the amsoil arrives
question is ...okay to use Semi-Synthetic then to Synthetic?
I believe you can not go Synthetic then to Semi-Synthetic Correct?
  • The Spanky
Posted May 09, 2009 - 06:06 PM
You can switch oils every time you drain if you wish. It won't hurt anything as long as you re-fill with the correct viscosity.
  • pbviking
Posted May 10, 2009 - 06:56 AM
i believe once you go Synthetic then you can not go back to Semi-Synthetic or regular 10-40
Posted May 10, 2009 - 07:07 AM
Not true. Synthetic, petroleum, or semi/blended, it makes no difference. They can be freely interchanged, and even mixed (although it's not recommended that you mix two different oils as a usual practice).
The only engine lubricating oils you can't do this with are any of the true castor based oils, which are rare and expensive, and you would know if you were buying it.
  • pbviking
Posted May 10, 2009 - 07:13 AM
thank you Gray :excuseme:
  • The Spanky
Posted May 10, 2009 - 08:10 AM
When synthetics were first introduced, they had pronounced seal-swelling propensities. If you ran synthetic, the seals would swell. If you switched back to a non-synthetic, the seals would shrink again, but since they had become crushed by swelling in a confined space, they would now leak. That's where the myth of not being able to switch back came from. It's no longer the case.
  • pbviking
Posted May 10, 2009 - 05:46 PM
cool
thank you :excuseme:
  • Hot  113 replies
  • 10 replies
  • On January 15, 2017
  • 0 replies
Motocross
  • Hot  491 replies
