can you use stop leak in a wr 400 ?
2 replies to this topic
  • biohazrd
Posted May 08, 2009 - 06:50 PM
what would happen if I used radiator stop leak for trail emergencies? will it gum up the works? in auto systems it is added to extend water pump seal life, any thoughts? as you may have guessed this is my first water cooled.
  • Flagstaff
Posted May 08, 2009 - 07:44 PM
Sent dented radiator with leak to mylars for repair, reinstalled and had very small leak after reinstall only when running. Wouldnt even show up with 40lb pressure test. Called Mylers, recommended "pinch" of alumaseal. Worked immediately.
  • biohazrd
Posted May 09, 2009 - 05:06 AM
thanks, I'll try it
