gasket sizes
4 replies to this topic
  • KTM250powerband
Posted 08 May 2009 - 12:57 PM
do gasket mm sizes matter? like for cylinder to case gasket, does the mm
size matter?
  • Little Jeff
Posted 08 May 2009 - 01:29 PM
The gasket size determines your x demension. There should be 4-5 different gasket thicknesses for most KTM's. You have to measure with a set of calipers. Yes, it does matter.
Little Jeff
  • mooseeetracks
Posted 09 May 2009 - 09:36 AM
lol well thats not good, im not much of a mechanic, but i flooded my engine with muddy water when i fell over in a huge puddle, i took apart the carb, top end, reeds, and flushed the crank with gas/oil, cleaned the exhaust, pretty much did everything, but obviously i had to take off the cylinder do i had to replace the gasket, i didnt know there were different sizes before i went to the shop, i didnt know what to get so i just got a 75mm gasket (the thickest one). i put everything back together and now it wont start, i used starting fluid, checked the plug, and gas, and everything seems to be fine, but it wont even kick over, any idea what could be wrong?
  • skatpex99
Posted 09 May 2009 - 01:13 PM
If everything else on the bike is fine, then your compression is to low becasue of the thick gasket you used. You may need to order a thinner gasket.
  • mooseeetracks
Posted 09 May 2009 - 03:01 PM
damn lol well hopefully thats not the problem, but thank you for your input, once i get a new spark plug and really go over everything ill definitely consider replacing the gasket
