GYTR Flywheel arrived - Yamabond?
13 replies to this topic
  • davcon
Posted May 07, 2009 - 05:47 AM
Its the 9.21 Oz, been backordered for a while, cant wait to install and try it out. Came with a new gasket. Anyway, the manual and the included instructions specify Yamabond or Threebond for the CDI grommet/case connection. I have blue and red permatex, will one of those suffice? Thanks
Posted May 07, 2009 - 05:52 AM
If you mean RTV silicone, no, not very well. Use Permatex #3 ("Avaition") or a trim adhesive type sealer.
  • davcon
Posted May 07, 2009 - 06:00 AM
Thanks Gray, So its more of a glue than a sealer then. Ok, since I've got to buy a new "sauce" anyway, I'll get the Threebond.
Posted May 07, 2009 - 06:16 AM
Some RTV sealers say on the label that they "form gaskets". That's not really the case. In order to work, the sealant must form an adhesive bond to both parts it contacts that won't be weakened by the fluid involved. I find that "normal" RTV silicone doesn't bond well to rubber such as found in the grommet on the stator harness.
  • davcon
Posted May 07, 2009 - 06:24 AM
:excuseme:
  • jriorda1
Posted May 08, 2009 - 05:01 PM
I just put mine on, granted the bike only had 3 hours on it, but I just layed the bike over and did not even disconnect the CDI. I just zip tied it to the side after I took it off. Swapped the weights and slapped it back on, no glue even used the old gasket
  • davcon
Posted May 08, 2009 - 07:05 PM
good to know thanks:thumbsup:
  • RCannon
Posted May 09, 2009 - 02:18 AM
Great tip, grayracer. Is the permatex 3 hard to find?
  • davcon
Posted May 09, 2009 - 06:49 AM
My dealer only had Hondabond 4. Told me same as Yamabond. Hope they're right.
Posted May 09, 2009 - 07:06 AM
Not around here. Any "real" auto parts store should have it. It's a brush-in-can product, and it's a bit messy as is. I use cheap art brushes from the 99 cent store to apply it to things like the harness grommet on my bikes.
Products like the Yamabond are neater.
  • DPW
Posted May 09, 2009 - 09:01 AM
I did the same and even after a timing chain replacement at 70 hrs no leaks
  • buzzfin
Posted May 09, 2009 - 12:59 PM
Me too...
  • davcon
Posted May 10, 2009 - 07:07 AM
As jriorda1 and others said, if careful removing the side cover nothing is required except blue loctite and a puller. Rode for a 35 miler yesterday, no issues.
Posted May 10, 2009 - 07:11 AM
Something that may prove helpful:
http://www.thumperta...ad.php?t=568177
  • Hot  47 replies
Motocross
  • Hot  491 replies
  • 0 reviews
  • 0 replies
