05 stock exhaust DB's
6 replies to this topic
  • Lennie
Posted May 06, 2009 - 11:47 PM
Hello,
I have searches and search but I cant find the DB level for the stock 05 yzf exhaust. Can anyone tell me? :excuseme:
Cheers.
  • 426 NOOB
Posted May 06, 2009 - 11:49 PM
Hello,
Cheers.
an accurate guess would be from 98-108 db. Depending on how its tested
  • Lennie
Posted May 07, 2009 - 01:05 AM
98 and 108 is VERY different !!!!!!! 98 is ok but 108 is way to loud !!!!!
Posted May 07, 2009 - 06:03 AM
That's a lot like guessing that you weigh between 100 and 300 pounds. :excuseme:
  • 426 NOOB
Posted May 07, 2009 - 07:32 AM
there is a lot of vaiables, such as if the pipe is freshly packed and how close it is tested. Every time I have been tested the person has done it differently than the time before.
Posted May 07, 2009 - 09:36 AM
there is a lot of vaiables, ...
Obviously, but there is also a standard process by which they are supposed to be tested, and when the question is asked regarding sound output of a muffler, the assumption is that the muffler will be in good condition.
Decibels are logarithmic units using Base-10 logs. Each successive dB then is ten times as powerful as the previous one. Thus, the sound at 108 dB has enormously more sound pressure than 98, not simply ten percent louder, as the numbers would suggest.
  • Lennie
Posted May 08, 2009 - 01:11 AM
I know this, does anyone have a more accurate figure for the exhaust db's please?
Motocross
  • Hot  491 replies
  • Hot  33 replies
  • Hot  47 replies
