05' Carb
2 replies to this topic
  • 426 NOOB
Posted May 06, 2009 - 11:19 PM
I am from the yzf forum but am working on a wr for my buddy. It had been sitting for 3 years with gas in carb. It ran but only wide open so my first thought was the pilot circuit. I pulled it and thoroughly cleaned all jets and passageways with large quantities of brake clean and 120 psi of air. It was spotless when I re installed it on the bike. I set the fuel screw two turns out and all jetting is totally stock. I also made extra sure that there are no air leaks. The bike actually idles now, but pops and studders. Wide open is still okay. I am only at 1200ft. elevation and just want it to run cleanly as the guy is not that good of a rider. What are the things commonly missed that would cause these problems? Any help would be appreciated. Tomorrow I will play with air fuel screw some more and take it on a test ride. Thanks
  • William1
Posted May 07, 2009 - 03:22 AM
Replace the pilot jet, cleaning is a waste of time.
  • 426 NOOB
Posted May 07, 2009 - 07:36 AM
how so? is it because its not straight through because of the holes?
