how much?
1 reply to this topic
  • eduardo
Posted March 07, 2003 - 07:12 AM
Ok, how much should i cut the accelerator stop screw in the wr426?
I saw one guy talking about 8mm for the wr400 model.
I also read 11mm for the 450 model.
What about the 426? :)
Thanks in advance.
  • Indy_WR450
Posted March 07, 2003 - 05:30 PM
Pull the carb out and remove the screw. Turn the spring loaded throttle wheel until the slide just clears the opening. That is the position that the bolt must hit the stop flange on the throttle wheel. Measure the distance through the bolt hole to the flange and cut the bolt appropriately.
