Rekluse Review
Posted 03 May 2009 - 06:05 PM
So I ordered it, installed it and headed for the track. The first weekend I was a little disappointed but I wasn't used to it yet. The next weekend I started liking it a little better but it was still up in the air.
After riding with it for four Saturdays now I can honestly say that when you are out on the track, about the only thing it is good for is brake sliding. I own a nice stadium style track http://happytrack.co...ml/track_4.html and the only time it comes into play is on four corners that I can charge into real hard and I'll brake slide to make quick turn. The Rekluse makes it a little easier because I don't have to use the clutch to do the brake sliding so my forearm doesn't pump up as fast.
I would suspect on an outdoor track the Rekluse wouldn't even come into play other than maybe the start but I can't tell you anything about that because we are just a practice track.
The light clutch pull is a nice feature. I still use the clutch to take off from a standing start or going into slow inside turns.
The bike will still stall if you blip the throttle and you are not moving fast enough, very annoying.
Another annoying feature is that you can't/it won't bump start if the engine stalls.
When it is all said and done, I'll leave it on, but I don't know if I would ever do it again.
Posted 03 May 2009 - 10:54 PM
Posted 03 May 2009 - 11:47 PM
Posted 04 May 2009 - 05:15 AM
ThmprJmpr said:
Modern day motocross bikes are designed so that you do not have to use the clutch to upsift.
Posted 04 May 2009 - 11:18 AM
Posted 04 May 2009 - 11:32 AM
john01 said:
I just got done talking to a tech guy at Rekluse and he said that for my application (tight track) that I might like it a little better if I take out three of the balls for a softer engagement rate. I'll try it this weekend and report back.
Posted 04 May 2009 - 12:31 PM
Posted 04 May 2009 - 12:37 PM
Posted 04 May 2009 - 09:56 PM
Posted 05 May 2009 - 02:22 PM
Posted 05 May 2009 - 02:29 PM
Posted 05 May 2009 - 02:38 PM
willbilly said:
That's what the tech guy told me, remove three balls. I'll be trying it out this weekend and see how it works.
Posted 05 May 2009 - 02:44 PM
gruberyz said:
The general concensous seems to be that the Rekluse is an awesome addition for an off road and trail bike. I don't ride offroad or trail but if I did I wouldn't hesitate to install the Rekluse.
There just dosen't seem to be as much of a benefit on the track. Also, on the track, I think the faster you are the more the benefit diminishes.
Posted 05 May 2009 - 09:03 PM
I think you're exactly right. I'm going to turn my '07 R into a single track monster and I think the Rekluse would be the perfect mod. If you want to sell it let me know since we're neighbors.
Posted 06 May 2009 - 07:56 AM
Performance wise, I don't see that you give up anything aside from the bump start. You can still override and feather the clutch like normal. If you are in a points series, how much would it be worth to you to get back the points you lost cause you spent half a lap re-starting a hot bike? Not important to everyone, just something to consider.
Posted 06 May 2009 - 08:12 AM
Posted 08 May 2009 - 08:47 PM
