yz426 suspension questions
6 replies to this topic
  • keegan1014
Posted May 02, 2009 - 05:05 PM
anyone know were I can get parts?
forks are way to stiff and dont adjust enough
need a good link to a site.
Posted May 02, 2009 - 08:46 PM
This site. What parts are you thinking you need?
  • keegan1014
Posted May 03, 2009 - 03:35 AM
Im thinking springs and a revalve Gray
the bike was set up for a 250lb rider and im 185
if you think I need something else please tell me what ill need.
the forks are hard as a rock, and I tried the adjusters.
  • 642MX
Posted May 03, 2009 - 07:05 AM
I'd say your going to need springs and a revalve. This guy knows his stuff with Yamaha's: http://www.smartsuspension.com
Posted May 03, 2009 - 08:50 AM
Start with springs. Check the manual for the stock rates. At 185, you should be good with those, and you may try an add in the classifieds to see if anyone has some stock stuff for a 426 around.
You can also look into the spring rate calculators at Race Tech Suspension and MX-Tech suspension to see if it says anything different. The TT Store sells fork and shock springs from several different sources, and can set you up with what you need.
Once you have the right springs, you can determine whether a revalve is needed or not. With the current springs, you'll never be able to tell.
There are two schools of thought on revalving (actually three, in my mind):
  • Send the forks to a big, top tier national suspension shop, and stand a decent chance of getting something you like the first time, or,
  • Take it to a local shop, spend a little less, and have more immediate support for changes and adjustments after the job
The third way would be to send the fork and shock to Smart Performance and have Dave Johnson throw his latest stuff in them. He gets truly amazing results from the old, open bath fork design, and is the way to go if you want the best there is.
  • keegan1014
Posted May 03, 2009 - 01:25 PM
thank you men
  • 02WR426Cali
Posted May 03, 2009 - 02:57 PM
They make great stuff and do good work! Talk to the owner John, he is a very helpful guy
  • 5 replies
  • Hot  79 replies
Need help by Goforaride
  • Hot  68 replies
  • 0 replies
  • Hot  33 replies
