PINK DRIPS
5 replies to this topic
  • QUALCAST
Posted February 16, 2001 - 09:14 AM
hey all ,,since picking my wr up i have noticed some drips of pink looking fluid coming out of the big breather hose infront of the gear lever ,,its only 3-4 drops just after i turn her off ,,,,i'm sure i read about this before but a search found nothing ,,can anyone shed some light on this
thanks ,,,,adam
  • ButtonFly
Posted February 16, 2001 - 10:08 PM
Going out on a limb here. What are you running oilwise in the gearbox? It better not be ATF. The big hose is the crankcase breather. What year is your WR?
  • Boit
Posted February 16, 2001 - 06:14 PM
Does the oil you run in your engine have a redish color? If it is, then that pinkish dishcharge is perfectly normal. My oil is amber and discharges a few whitish milky looking drops sometimes. Without going into detail why this occurs, it's basically a result of a little bit of moisture mixing in with the hot oil vapors that are vented via that big line.
  • SFO
Posted February 16, 2001 - 06:22 PM
yup, I reckon your breather hose is bound to puke some.
Check the reroute entries, you are warned...
  • QUALCAST
Posted February 17, 2001 - 01:46 AM
Thanks for the responses guys ,,yes its a 99 wr and yes the oil is red in colour at least now i can get on with enjoying the beast!
thanks again
adam
  • bonez34
Posted February 18, 2001 - 06:55 PM
make sure you are using 4-stroke oil and NOT 2-stroke gearbox oil, i know the honda 2-stroke oil is red in color.
