decompression arm is leaking, how to block off.
7 replies to this topic
  • bluebreadtruck
Posted May 01, 2009 - 08:12 AM
I dont need my decompression anymore since i got outo decomp cams, how do i block off the hole where the arm comes through? makes valve adjustment hard, and leaks a bunch of oil!
  • Birdy426
Posted May 01, 2009 - 10:00 AM
http://cgi.ebay.com/...sQ5fAccessories
  • bluebreadtruck
Posted May 02, 2009 - 09:35 AM
thank you sir.
Anyone know where those can be found not on ebay? thanks
  • byggd
Posted May 02, 2009 - 03:22 PM
thank you sir.
The thumper talk store! Where ever you buy it from take care when installing the retaining bolt. A bit too much mojo and the threads will pull out!
  • tcmII
Posted May 02, 2009 - 05:57 PM
I left the lever in with the auto cam. If was free.
  • bluebreadtruck
Posted May 03, 2009 - 02:04 PM
Indeed, i allready did this. Looks like i will have to helicoil the bolt, to even get the plug to stay in....figures...
  • maxtherat
Posted May 06, 2009 - 09:56 AM
A cheaper route is to by the rubber plug from Yamaha. 03-05 wr uses same hear casting as older 426's. The aluminum plug is much more reliable though. Rubber plug can come out if hose from valve cover is kinked.
  • DrBosa
Posted May 07, 2009 - 09:58 AM
Or it can come out anyway, like mine did. Alu plugs are probably best, but rubber plug works too. However, use motor silicone to get it to stick. Or drill a hole through a small metal sheet, bend it 90 degrees and mount it using the screw (on the bike's right side if the decomp hole). This will protect the plug from blowing out.
