yz 450 exhaust problem
5 replies to this topic
  • patm
Posted April 29, 2009 - 06:10 AM
i have a 2004 yz 450 and have the work conection heaver suspension on it and now the pipe rubes the suspension i was wonder if anyone knew of any pipes that are small and woundnt rube.
  • spark250
Posted April 29, 2009 - 09:21 AM
So the spring is rubbing the exhaust? Doesn't seem to make sense?
Most aftermarket pipes will be the same or bigger diameter than stock.
Posted April 29, 2009 - 09:30 AM
It sounds like the spring is the wrong one for the bike. There is no reason for it to contact the mid pipe unless the spring is the wrong diameter, or the frame is bent.
  • patm
Posted May 01, 2009 - 06:40 AM
it started to do that once i got the aftermatket spring wich is thicker then stock
Posted May 01, 2009 - 06:55 AM
That's my point; it's the wrong spring.
  • mikedabike
Posted May 01, 2009 - 07:18 PM
My 04 did the same thing with the works connection spring. I always assumed the pipe was tweeked a bit or something. I never did anything about it because it was very minor. I never noticed it rubbing but would notice a small amount of paint rubbed off the spring when I would be doing maintenance. Try to see where it is rubbing and see if you can loosen the pipe and pull it away a bit then try to retighten and see if you can gain a bit of clearance.
  • Hot  33 replies
  • Hot  36 replies
  • 5 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • 9 replies
