hey nick,
here's a tidbit of advice -- it's not possible to have just one
torque wrench which will suit all needs. the camshaft cap bolts, for example, require 7.2 ft-lbs of torque. on the other hand, the steering head nut requires around 100 ft-lbs. you will find it difficult to get a wrench that covers this wide range AND is accurate near the extremes.
my suggestion then is to start small. i say that because it is much easier to snap off a 5mm dia bolt on your engine than the bigger bolts on your frame. what i mean by this is that accuracy is critical when you are talking 7.2 ft-lbs but not so critical when you are talking 100 ft-lbs.
so my recommendation would be to get a decent 3/8" drive torque wrench that goes from about 10 to 50 ft-lbs. this will cover lots of bolts on your bike including the critical fork tube clamp bolts.
later you can get a 1/4" drive torque wrench, one that goes from about 48 in-lbs (4 ft-lbs) to 240 in-lbs (20 ft-lbs). this allows precise tightening of internal engine parts, like those cam caps.
finally you can get a big 1/2" drive unit, that goes to 140 ft-lbs or so. used on rear axle, steering stem nut, etc.
by far i get the most use out of the 3/8" torque wrench. when you change your oil you'll need this (or perhaps you can use the 1/4" drive) to tighten the oil cover cap bolts. if i recall correctly they are torqued to around 17 ft-lbs.
as for brands...
as i have opined several times before, i think that STANLEY-PROTO represents the best value in torque wrenches these days. basically they are Snap-On quality at 1/2 the price. you can occasionally pick one of these up on ebay for a really nice price. but sears/craftsman also have some nice wrenches, as does husky and so forth. the torque wrench topic has been discussed many times before, just do a search and change the search timeframe out to a year or so.
fwiw, i have 2 PROTOs (1/4" and 3/8") and a husky (1/2").
jim aka the wrooster
'01 wr250f
