I own this
MotionPro FCR carb tool (here is
their link). Notice the blue Sears finger screw driver in the picture - one end allows for any hex bit and the other allows for it to be used with a 1/4" socket wrench. It also has a magnet inside the aluminum blue finger piece so that the bit will stay put. Well, it turns out this piece works perfectly to adjust our Keihin carb's fuel mixture screw and it only costs
$1.99 IIRC!
OK, not quite perfectly since the bit that it comes with (phillips or flat head) is about 2mm too wide as you can see in
this picture where I have my 5/32 bit that has the correct width corresponding to the proper MP's bit to use for our Keihin carb (this is the short bit right above the bottom 2 bits). This is the
MP tool with its correct bit for our carb. Here is the
Sears' tool with the MP bit attached - noticed that the hex base of the MP bit is just slightly smaller than the standard hex bit setup and there is some play but it works fine inside the Sears' tool. The Sears' tool is very well made, while the MP's hand piece is made of plastic (I think) and is a bit cheesy. I marked the Sears' tool with a Sharpie so that I can tell where the 1/2 and full turn points are (notice the black line - I used 2 lines on the other side to indicate the difference between the 2 measuring points). Here is another picture of
the Sears' tool with the MP bit attached - you can use
any standard flat head bit as long as the width is not too wide and it will work - I'm guessing the width is around ~4mm wide (my 5/32 bit worked well for this application).
I found the Sears tool the other day sitting on their checkout counter (in a box full of them) and thought this is "perfect" - took it home and it worked out really well!
Oh yeah, you have choices of colors too, and I chose BLUE of course
