wr 400 bad engine vibrations
2 replies to this topic
  • Ruff 400f
Posted April 26, 2009 - 03:50 PM
I was out having a good ride when the bike started to vibrate quite bad. It was worse at high revs. Could feel it through the bars really bad. So I took the clutch cover off and the springs, and found the big nut had come loose. No doubt because I didnt have a clutch holding tool when I was last mucking around with it.
Anyway I tightened it all up again and the vibration was gone. Ripper I thought, but now its back after another good ride. I checked out the clutch again and the nut was still tight. I took the basket off again and checked it all out, put it back on again, started it up and BBBZZZZZZ. The vibration still there.
I looked at the cams and they look fine ?
A few shavings in the oil filter, looks normal to me( there is always some crap in there).
I was thinking maybe riding it with the loose clutch has now wrecked the brass bearings on the primary drive gear ??
There is only the slightest bit of movement if you try to wobble the clutch assembly when its on the bike all bolted up ??
Any ideas ??
  • Ruff 400f
Posted April 28, 2009 - 04:53 AM
Hey crisis over. I found two loose engine mounts. Looks like the vibrations from the loose clutch shook loose some other bolts. better put a bit of thread lock here and there.
  • spin9
Posted April 30, 2009 - 10:32 AM
Hay while you are in there keep an eye on the nut on the end of the crank as well. I have seen several of those come loose.
