How to fix a slipped cam
No replies to this topic
  • pablo83
Posted April 26, 2009 - 02:05 PM
I was riding the WR426 when it made an odd engine noise and lost power and compression. I had a look and found this:
Cam gear timing is set right:
But the intake cam is off:
Turns out a lack of oil to the cam bushings caused it to seize and spun the cam gear. I had checked the head recently so it must have taken too long to refill the head with oil. I had reassembled the head with assembly lube, but I did not pour oil directly into the head.
I'm taking this bike to Moab in less than a week so I don't have time to order parts. The head is fine, but upper cam bushings were overheated and the cam would not spin freely in it. I sanded the bushing down by hand with emery cloth until the cam spun smoothly in it. Then I welded the cam gear in place and put a new timing mark on it (two teeth clockwise of the original mark):
The gear metal is VERY hard. This is what it did to my favorite punch when I made the new mark:
The bike rips again. We'll see if it holds up or if the engine grenades in the middle of the White Rim Trail.
