2004 YZ 450 idle problem
5 replies to this topic
  • gorgev
Posted April 24, 2009 - 06:00 PM
bought bike used, not ridden much, could not get to idle, idles ok sometimes, then sometimes revs higher, like on a fast idle. bike backfires too. And when riding if i press the clutch the engine turns off. Any help would be appreciated. Thanks
  • wondermuscle
Posted April 28, 2009 - 06:54 AM
Interesting...... Pulling in the clutch kills the motor that wants to idle high.
First I would check the idle circuit and verify that the pilot jet is not partially clogged. It may also be too small and starving for fuel.
Report back what you find with the pilot and we can go from there.
  • gorgev
Posted April 28, 2009 - 06:01 PM
Thanx for the post. I cleaned the carb today and still the same. I will order new pilot jet tomorrow. What do you think about getting the JD Jetting kit? Will it help me? And sorry for my bad english :banghead:
Posted April 28, 2009 - 08:30 PM
Before you buy the jet kit, check the valve clearances.
  • gorgev
Posted April 29, 2009 - 12:13 PM
I think that the valve clearances aro ok couse I changed the valves two months ago because they got damaged for some reason. I could not find any jets around so now I will have to wait a week or two :banghead:
  • gorgev
Posted April 29, 2009 - 12:16 PM
And the bike had the same problems before the change of the valves. And the thing is there is no good mechanic around to fix my bike :banghead:
  • Hot  28 replies
  • Hot  47 replies
