Spark Plug Reading
6 replies to this topic
  • tdjok
Posted 04 March 2003 - 04:01 AM
My spark plug reading makes little sense after viewing many TT posts. So far I have not read where anyone is using a 180 or larger main jet. Most are 178 or smaller and seem to be working well.
Trying to do a little fine tuning, I conservatively dropped the mj to a 182. I ran the bike a 1/4 mile in 5th at high rpms and shut it down. Pushed it to my shop and checked the plug. To my surprise, the ceramic was bone white, indicating a lean condition.
Based on this test, I need to go back up to the stock 185 or higher. I just thought this was odd as I have not read any posts of riders using the stock mj.
Ride safe.
Terry
  • Mudman
Posted 04 March 2003 - 05:25 AM
Are you using an aftermarket exhaust or stock exhaust?
  • ksp
Posted 04 March 2003 - 06:48 AM
To do the test properly you need to run the bike at FULL throttle, hit the kill switch and coast to a stop, then check plug reading. Looking at your post, I would assume Oklahoma is close to sea level and running a T-4 pipe, a 185 or maybe slightly bigger main wouldn't surprise me. Also how cold was it the day you did it? That could have some effect also.
  • tdjok
Posted 04 March 2003 - 07:10 AM
To answer Mudman, the exhaust is a stock head pipe and Pro Circuit T-4 silencer.
I did the test just as you mentioned. This is my first four-stroke off-road bike so I was guessing that my old two-stroke procedure would work fine. Sounds like it is correct.
The temperature was a beautiful 58f and we are at about 1,200 ft.
Terry
  • Mudman
Posted 04 March 2003 - 07:52 AM
I agree with ksp, you definatley want to go with a bigger main. You're better off a little rich than a little lean. I'd assume with the airbox mod and the pro circuit, you've increased the flow at both ends.
  • WhyZ
Posted 04 March 2003 - 04:33 PM
Quote
Being that the ceramic was or is white,does not necesserally mean thats its a lean condition.
You need to read way down inside of the insulator to get an accurate reading. Check this out on how to read a plug.
http://www.dirtrider...tting+help+fast
  • tdjok
Posted 05 March 2003 - 02:46 AM
Thanks for the link, I'll check it out.
Terry
