How to wire 2 batteries in series?
17 replies to this topic
  • Bill_B
Posted April 22, 2009 - 05:17 PM
New to all this just got a travel trailer.
If I have 2 batteries on my travel trailer how do you wire them together in a series? There are 4 wires 2 black 2 white What is hot? how do I wire them?
:banghead:
  • dkipz
Posted April 22, 2009 - 06:30 PM
Keep in mind wiring in series will add the voltages of the 2 batteries together (ie 2 6V = 12V, 2 12v=24V) If you have 12V batteries you probably want to go parallel, as the voltage remains the same. Anyhow, series: + of rig to + of battery 1, - of battery 1 has a jumper lead to + of battery 2, - of battery 2 to - of rig. Parallel: "piggyback" the batteries + to +, - to -.
Hope this helps!
Dan
  • brad the best
Posted April 22, 2009 - 07:52 PM
http://www.zbattery....19a839ae9849759
  • Bill_B
Posted April 22, 2009 - 09:56 PM
Ok I guess I need to be more specific and get the terminology correct. Looks like I need to buy new batts so I’m going with 2 12V witch will give me more ban for the buck right?
I will wire in parallel.
Just to make sure the unit has black and white wires NO red.
White is hot?
Black is Negative?
RIGHT??
  • 04sierrahd
Posted April 23, 2009 - 01:37 AM
The best bang for your buck is to buy two 6V golf cart batteries. You can get them at Les Schwab. They're a little more expensive than a 12V RV battery, but they work so much better. The power just trickles out, so they last a long time. You wanna connect them in a series, like the top diagram posted above, so that the two 6V batteries now form a 12V. The color of the battery wires is not important, but I believe white is normally used for positive, and black for negative. You can probably find good diagrams and instructions on the internet if you Google it..it's a popular thing to do. I did it on my toy hauler, and will never go back to 12V batteries.
  • redhurricane
Posted April 23, 2009 - 05:28 AM
Do some reading before you make a decision on buying 12v batteries for your RV:
http://www.ccis.com/...volt/12volt.htm
  • dkipz
Posted April 23, 2009 - 06:07 AM
If you have 2 whites and 2 blacks chances are you were wired for 2 12V batteries already, unless the 2nd pair of wires was added for an inverter/generator etc. but the easiest way to be sure what you've got for wiring is to grab a multimeter and ground one lead to the chassis (frame) of the hauler, and meter all 4 leads for resistance. I'm guessing the 2 black ones will get very close to 0 ohms resistance - those would be the grounds. The other 2 will show more resistance and would be the hot leads. If you want to series wire that arrangement just parallel the 2 wires you found to be ground, and parallel the 2 other wires together, then do the series wiring for the 2 lugs that you created. Keep in mind that if you do go the 6V route you'll need to buy a battery cable to go from battery 1 + to battery 2 -.
Dan
  • Pukeballs
Posted April 23, 2009 - 09:52 AM
Or for 4 or more batteries
  • BigRichard
Posted April 23, 2009 - 12:36 PM
I agree - I bought 2 golf cart batteries at Costco for $75 a piece. I don't need to start my generator in the morning after running the heater all night. Plus they fit in the group 24 battery boxes that came with the trailer.
  • TobyG
Posted April 23, 2009 - 01:32 PM
Just added batteries to my trailer and I went with two 6V batteries from Sam's Club. 1 year full replacement warranty no questions asked. So, now if I screw up I've got a safey net. $73 220 A/H.
I'd also suggest (if your trailer didn't come with one) a battery monitoring gage. $30 on-line and at a glance can tell you when your batteries get down to 80% - 50% so as not to let them get too low.
The following two links were very helpful in answering most of my questions regarding batters for my trailer.
http://bart.ccis.com...olt/12volta.htm
  • Gadsen
Posted April 25, 2009 - 05:23 PM
:banghead:
If they are both 6 volts, I assume you want 12 volts. Run a jumper from + on one to the - on the other. The remaining + and - post is your 12 volts. If they are parallel, ie 2 12V batteries, + to +, - to -.
  • 5Guys2Go
Posted April 28, 2009 - 11:00 AM
OK, further on this subject.
1. What size wire should one use for the connection from one battery to the other?
2. Can you use the interior trailer lights, radio, fan, etc.. when you have the batteries on the charger to top them up? I thought I might have to unplug the batteries to charge them, but maybe not.
Thanks
  • kc_450_X
Posted April 28, 2009 - 12:11 PM
Put a night switch on the batteries when you charge them...
  • RV Wrench
Posted April 28, 2009 - 07:05 PM
Thanks
1. Use 6g wire. You could probably get away with 8g, but I would stick with 6g.
2. What charger are you referring to? The converter in the trailer? Most RV's have at least a 30A converter, which is MORE than enough to run all the 12v appliances and still charge the battery. Check your converter to see the output. Most auto style battery chargers are less than 15A.
And just on another note, the pics showing how to connect batteries in parallel are OK, but not "the best". When connecting in parallel, connect the postive from the trailer to one battery postive, but connect the negative from the trailer to the negative on the other battery negative. This equalizes the resistance in the connections and allows the batteries work in sync better and last longer. If you connect the trailer leads to the same battery it tends to work that battery more and shortens it's life. This also shortens the life of the other battery, as unequal paired batteries tend to only be as good as the worst one. :banghead:
  • desertlover
Posted April 29, 2009 - 08:40 AM
If you have black and white wires. The black is ususally the hot or positive, while the white is the common or ground.
  • jsdak
Posted April 30, 2009 - 08:07 AM
What about 4g wire? Would that create any problems?
  • kc_450_X
Posted April 30, 2009 - 02:15 PM
on it wouldn't cause a problem, it would just cost more tho
  • L-vie
Posted May 01, 2009 - 05:30 AM
The bigger the wire (smaller the guage #) the better it will be.
