how do you adjust forks on a yz426f
I was thinking this was true read somewhere here add something like
5 oz per xyz added weight,
so I have to drain the forks and add a specific amount because in 185lbs
not 250 like the PO
does this sound right?
No. To start with, if the PO changed springs for his weight your efforts to fix this without going back to the stock spring rates are a waste of time.
Second, you need to measure the current oil level to see where it is before making an adjustment.
Also, it occurs to me to ask if you know that the compression adjuster is on the bottom of that fork or not?
Underneath the rubber plugs on the bottom of the forks (if they are still on there) you will see a small straight-slot screw...that is your compression clicker (adjustor). The adjustment range is 0-20. Click them all the way in and then a good starting point would be to back them out ten clicks. Ride & adjust from there.
