Scratch start... In any electric welding process, you need to get an arc between the work material, and the electrode... this is what provides the heat to melt the material and/or the filler material... In TIG, esp. DC welding, you strike (or scratch) the electrode on the material to be welded to initiate the arc... you then pull the electrode away a small amount and maintain the arc, and you are now officially welding... On some higher spec machines, esp. those that do Ave an AC circuit, you have an option to initiate the arc by a momentary surge of voltage, rather than having to physically strike the arc - this HF start is great, because you cannot contaminate the electrode or the work piece... in TOG welding, the electrode should never touch the work...
Your teacher should have gone through it or supplied you tables or a textbook to calculate gas flow rates, electrode selection, cup sizing, current ranges etc...
The best pattern is a small circular one, esp. with Aluminium... then you are going ahead to preheat the metal, going back to keep the bead fluid, and catching the sides to make sure both bits of material are being heated and included in the weld pool... For aluminium, it will cool so much faster, and conduct away heat from the weld pool to the surrounding metal... so you need to keep the heat up in the whole perimeter of the weld pool...
As for filler, heat the base material, add the filler into the weld pool, and let it flow... you should be able to include the filler rod in your circle so it melts, without interrupting the arc... you cannot really push the material with the filler rod or the electrode... it just has to flow, as long as the weld pool is hot enough, it will...
The pedal regulates the current and therefore the weld depth and the bead appearance... once the arc is established, and the material is flowing nicely, you don't need to add more power, in fact, work a bit slower with the same power and you will get much better bead appearance. don't let the bead get too wide, or let the arc wander...
David
