Which replacement lever?
3 replies to this topic
  • nickinohio
Posted 03 March 2003 - 05:06 PM
I bought a Works Connection Pro Perch w/ Hot Start clutch lever, and I need to know what levers fit it. I would like to add a few spares to the box, but does any CR125/250 lever work (it says it is a "CR style" lever). Thanks
Nick
  • 2003YZ250FRACER
Posted 03 March 2003 - 05:37 PM
I think it should. You could get a couple of CHEAP CR levers and try it.
  • hanger92
Posted 03 March 2003 - 05:48 PM
got the same on mine, and yes it's honda cr, like they say. The disadvantage is you don't get the trick roller bearing with the other levers. I like the msr replacements, and press out the bronze bushing and replace it with the bearing. I wish they'd start making shorty levers again!
  • Rick_Kienle
Posted 04 March 2003 - 06:04 AM
You can get replacement levers directly from works connection that include the bearing. They are probably more expensive though.
