426 piston
7 replies to this topic
  • randytbo98
Posted April 21, 2009 - 10:32 AM
yz 426 trying to decide on a piston. which brand? 13.5 or 12.5? would i benefit from the higher ratio for a trail/gravel pit bike?
  • davidl9999
Posted April 21, 2009 - 10:36 AM
13.5. Those will still run on pump gas. I don't have a brand preference although I generally go OEM for internal parts when possible. (obviously that's not the case here).
  • randytbo98
Posted April 21, 2009 - 10:49 AM
im looking at a je in the tt store. will they go in without having to change anything? are they worth getting??
  • davidl9999
Posted April 21, 2009 - 11:02 AM
I'd expect it to go in without changing anything mechanical. Definitely will need to go through the jetting routine when you're done (might want to check with JD for a kit). At least make sure the cylinder bore is straight and true and the plating is good and honed for the new ring. JE has a pretty good reputation. Never used their pistons myself.
  • randytbo98
Posted April 21, 2009 - 11:06 AM
its gonna be slid into a brand new oem cylinder with a hotcams ex cam
  • 426 NOOB
Posted April 21, 2009 - 12:43 PM
go for it.
Posted April 21, 2009 - 02:29 PM
I like CP pistons, but JE is also excellent.
  • 642MX
Posted April 21, 2009 - 08:04 PM
Get yourself a Wiseco 13.5:1. I had one and loved it. :banghead:
I don't think anyone makes a bad piston, but I've used Wiseco's for years with great luck.
  • Hot  113 replies
  • 0 replies
