Water/Coolant in the Weep Hole
4 replies to this topic
  • Paollo
Posted April 19, 2009 - 11:28 PM
My '03 was not used for a week. I have noticed a water/coolant droping in the weep hole during warm-up, when I rode her the droping water/coolant in the weep hole stops. Is this normal since the unit was not used for for just 1 week or there's something wrong with the water seal & coolant?
  • gator4life108
Posted April 20, 2009 - 07:20 AM
Dripping from the weep hole usually means the bearing, seals, or shaft is going bad. My thought on it
  • ch_250
Posted April 21, 2009 - 02:25 PM
look around on the forums a bit, you'll find that this is a common problem. my WR did it last summer. it leaked even after the bike was warmed up, so i replaced the seals, bearings and impeller shaft. now it only does it when it's cold. if it's below 10 degreez Celcius it will weep a bit. It's totally normal for WRs. many of them do it right from factory. Just make sure your oil isn't turning grey, and make sure that the bike is cooling properly. My impeller shaft was reemed at the end and wasn't turning enough. Make sure of those two things. If it leaks for more than about 10 seconds, do some more looking into it.
  • Paollo
Posted April 21, 2009 - 08:19 PM
Thanks for the reply guys!:banghead:
  • redrockwr
Posted April 26, 2009 - 08:29 AM
My bike leaked as well when it was cold. Below 40 degrees. It still leaks a bit but as soon as it warms up it quits.
