Glowing red exhaust pipe on yz426
10 replies to this topic
  • qbal18
Posted April 18, 2009 - 07:34 PM
ok my bike has been a real pain in the ass to start took me over 3 hrs, so i checked valves they are mint, i did a MAJOR carb clean and walla it fires up 3rd kick but now after 30 sec on choke the pipe is cherry red. i opend the fuel mix screw 1.75 turns. it has a pro circuit pipe but stock jetting its a 2000 yz426f
so really 2 questions what can i do for now? and i jave a jd jet kit on order from TT so when i get it what would be a good combo. i ride live at sea level and do most my rideign from sea to 4000 ft in the 15-25c weather (i live in vancouver bc)
  • yz480doinwork
Posted April 18, 2009 - 07:52 PM
if the pipe being red bothers you that bad...dont let it sit that long. this is pretty normal. does it run good other wise?
  • gbalias
Posted April 18, 2009 - 08:15 PM
bump up the pilot.
youre gonna need to richen it up all around if youve got a full system on there.
check the jetting FAQ/database and you should be set. but stock jetting on a full pipe is lean.
  • qbal18
Posted April 18, 2009 - 08:39 PM
i just got real worried cuz i just got this bike 2 weeks ago and it has not been runign until i just cleand the carb today and when i fired it up within 30 sec witht he chokeon it was cherry red, i have never had a bike do this befor but all my bike befor have been old gutless wonders.
so since i posted this i have been surching and found it is normal as well, so im not gona worry to much. im gona rejet asap would it help if i open up the fuel mix screw a bit until then?
  • USED YZ426F
Posted April 19, 2009 - 01:17 PM
Glowing red exhaust pipe is fairly common when the bike is just sitting there. Get out and ride it a bit and see how you like it.
  • 642MX
Posted April 19, 2009 - 02:02 PM
bump up the pilot.
Why? He didn't say his fuel screw was 4 turns out or anything...
Not true.
Not true again, the OEM system is a free flowing exhaust, just like 99% of the aftermarket stuff. If the jetting is good with the stock system, 9 times out of 10 you'll just have to adjust the fuel screw for other pipes/systems.
  • 642MX
Posted April 19, 2009 - 02:05 PM
Exactly :p
  • brAapingyz450s
Posted April 25, 2009 - 08:58 PM
haha a glowing red pipe is normal you need that thing 2 be moving!! air to cool it off the 426/450 run very HOT! first time i started up a 426 i thought there was something wrong with it cuz it started glowing within a few seconds but its normal my 06 450 does it 2 actually no biggie
  • GENE426
Posted April 25, 2009 - 09:02 PM
Exactly :banghead:
YUP
Mine I ran VP motorsport 103 and was perfect
pump gas and it was hard to start for some reason
  • JamesNad
Posted April 26, 2009 - 05:48 PM
i found letting my bike warm up for like a minute it will heat my coolant up and spite alittle out.
  • dgnretj
Posted April 30, 2009 - 12:18 AM
mine spits coolant if im running it trying to clear the gas out of the carb before i store it... im gonna just start riding it for a bit now so it sits less... but i dont get the red header
