Just bought a 2000 yzf 426 have a couple questions
23 replies to this topic
  • phart2005
Posted April 23, 2009 - 07:02 AM
#21
I read your post and didnt see this posted. IMO, the 2k is the best of the modern 4 stroke bikes **for what you want to do** which is very much the same as what I do. Mostly trails for me, dunes, roads, etc. I am no motocrosser for sure.
The 2000 has stainless steel valves, which will be more durable than the titanium valves that the 01+ bikes have, and they are a fraction of the price when you do need to replace them. If you are good at starting with the manual decomp, keep it. You can lug without stalling like an auto decomp will, and in the woods you will do just that from time to time.
And be sure to lug it, the 426 will rev, but she's got a ton of low end power, so find it and enjoy it.
IMO, dont put a 13 on the front. I tried it becuase I had one that fit, and I was right to the rev limiter in 5th gear. With a 14, I have never gone that fast. I think you would be happier with a 50 tooth in the rear, and the 14 on the front. I just bought a 51 to run with my paddle wheel/tire, i think that will be perfect.
Do the 01 clutch mod, you will be very happy. My clutch was a light switch, on or off, now it is smooth and linear from bar to released. Very predictable too. The parts will be around $100.
If you dont know when the valves were checked last, do it. Its not too bad of a job to check them, and if they need to be adjusted, thats not too bad too. If they start to run tight, you risk them leaking and then you will burn one.
I changed my piston out, just because, but once I opened it up, I dont think i needed to. Im not sure if I am happy yet either, the Wiseco I put in rattles a lot because its forged, and needs to be looser in the bore. But now i know that it isnt 9 years old and going to break from age.
Also, feel out your range with the stock gas tank. My bike gets 42 miles per gallon so I have not had issues in the woods, since we go from one place to another town with gas.
Enjoy your bike!
  • mike_dean
Posted April 23, 2009 - 03:12 PM
#22
Riding my 426 very hard in the sand on fast trails I ran out of gas at 44 miles, so the range will vary.
  • Wiz636
Posted April 23, 2009 - 03:38 PM
#23
Say what? How does an auto-decomp cam cause the bike to be more prone to stalling?
Posted April 23, 2009 - 09:48 PM
#24
I doesn't. I don't know where that came from, but the auto decomp mechanism has no ability to stall the engine. The YZ450 stalls more easily than the 426 because the 450 has almost no rotating mass, and a flywheel smaller than a gas cap.
  • 5 replies
  • Hot  50 replies
  • Hot  30 replies
  • Hot  38 replies
