To keep or not to keep??
6 replies to this topic
  • zippor25
Posted April 18, 2009 - 05:02 PM
So I bought a 07 YZ450F recently and no matter where I ride(no track ridding only trails) I cannot seem to get it past 3rd gear. Not that there is a problem with the bike, its just so fast that I never need 4th or 5th. I was wondering if I should downgrade to a 250 or just stay in low gears? Im a big guy like 280 so I'm not sure if a 250 is big enough.
  • 642MX
Posted April 18, 2009 - 05:09 PM
Shift up a gear and ride faster... :lol:
At 280 lbs, your on the right bike. Nothing wrong with using 1st & 2nd. :p
  • sacfelix
Once you trade down, if you do, you will be regreting you did once you get use to the bike. The extra power would be ideal for your weight. I have a 06 YZ450 and Im 5'11" and 204 pounds. I ride the bike on trails and I also race desert with it. Its a great bike!
  • rjcook450
Posted April 18, 2009 - 06:40 PM
i had same problem after adding drd pipe, i geared down by going to a 50t rear sprocket, makes third grear more usable for me now.
  • brAapingyz450s
Posted April 25, 2009 - 09:01 PM
haha keep it things a beast but maybe thats the problem just re-gear it deffintly dont go down! esp after your already on a 450 you'll be bouncing that thing on the rev limiter to try and make up for that power difference you were use 2 REGEAR IT!!!
  • hillclimbguy
Posted April 25, 2009 - 10:38 PM
I agree, go bigger on the rear sprocket to tighten up gear ratios. Maybe a 50 or 51.
  • DPW
Posted April 26, 2009 - 05:41 AM
gear the bike down and add the GYTR Off-road flywheel weight
