YZ timed Jetting advise
2 replies to this topic
  • darmino
Posted March 02, 2003 - 06:45 PM
Ok heres what I have, 2002 WR426 airbox lid off, YZ timed, gray wire removed, stock exhaust with insert removed, sometimes I run a baja design insert (only if I have to, about 70% of the time)Uni air filter. Fuel screw 2.5 out(The idle will not drop even if I back the fuel screw all the way out), stock jetting
My bike runs fine, but with the stock jetting am I missing out on some performance? I typically ride at between 1000-3000 FT, any advise?
:) Thanks in advance.
  • Hick
Posted March 02, 2003 - 06:51 PM
2002 WR426 airbox lid off, YZ timed, gray wire removed, stock exhaust with insert removed.
Congratulations. You now own a WR with a YZ motor. Switch to stock YZ jetting, this is a great starting point, or just leapfrog directly to the jetting of another member w/ similar altitude and climate.
But the stock YZ jetting will be such a big improvement over where you are now I feel compelled to mention that.
In a few minutes someone will be recommending an ELN needle...
  • Hick
Posted March 03, 2003 - 07:17 AM
Or maybe not.
I guess everybody bought a 450 and is out torquing their flywheel nuts. :)
