Water In The Oil
1 reply to this topic
  • music man
Posted April 17, 2009 - 09:07 AM
:p :lol: Newbie again
let me clear the question up a little . 2001 yz426f bought it from a friend
they say he walked the hound out of it. i got it home tried to start it
did not start so i checked the oil it was milkey so i draind all the oil flushed it out real good let it set for a few days to let it drain real good. replaced the oil with new oil . the bike started fine cut it off checked the oil it was milkey again . replaced the water pump seal problem solved. flushed all the milkey oil out again put new oil in started fine let it run for a minute or two cut it off
tried to start it back it sounds like the piston is scrubbing while moving up or down . moved it with a ratchet back and forth feels pretty good . so we tried to kick start it and it gets stuck. can free up with socket wrench fine just that one point it gets real stiff and wants to lock up. when i started it it ran fine dont under stand.
Posted April 17, 2009 - 09:39 AM
To begin with, the water pump seals cannot ordinarily cause cross contamination:
http://www.thumperta...240#post5775240
You may have simply picked up more sludge from the residue of the water that was in there previously. It WILL NOT drain out, no matter how long you leave it sit. But, you may also have a problem. Check the possible leak points listed in the link above.
The lock up issue could be a number of things, but you should start by inspecting the cam timing and the condition of the tensioner.
  • Hot  113 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  28 replies
