Please Clear Up Rear Sprocket Question 07 450
3 replies to this topic
  • Todddob
Posted April 16, 2009 - 08:35 PM
I have a 07 450. Stock chain and sprockets. 12 Hours run time. 49T rear right? Want to put new chain and rear sprocket on, if I change to a 50T I will get slightly more speed out of 1st and 2nd right? I don't want drastic change, just a little more speed when putting around in 1 and 2 with the boy. Thanks for the help.
  • erickdj
Posted April 16, 2009 - 08:43 PM
adding a tooth in the rear will actually reduce speed. One tooth in the rear won't really make a noticeable difference, I added 2 teeth and can barely tell the difference in speed, it pulls harder, but it doesn't make the gears much faster or slower. Adding 2-3 teeth in the rear would allow to lug the bike a little more when putting around.
Posted April 16, 2009 - 08:47 PM
You will get more engine speed with the larger rear sprocket, but at a lower vehicle speed.
When you increase the size of the rear sprocket, it takes more revolutions of the front sprocket to produce the same number of revolutions of the rear.
  • Todddob
Posted April 16, 2009 - 08:58 PM
Thanks Guys
  • Hot  28 replies
  • 0 replies
  • Hot  36 replies
