kx 125 trans oil
7 replies to this topic
  • brianandmell
Posted April 16, 2009 - 06:49 AM
I do understand there is alot diff ideas on this but i just need simple advise. My son has a 03 kx 125. I have been using yah. 20-50 2stroke trans oil with no prob. I was in a friends yah shop last week and needed some new oil and he gave me Honda's HP 80-85w 2-stroke trans fluid. I wasn't thinking and got it. I opened it up yesterday and noticed it was red and stoped. I don't want to put this in and have probs and have to clean the clutches, sugestions please?
  • KDXKRIS
Posted April 16, 2009 - 07:05 AM
That is fine to use in your KX and most likely will give him better clutch feel than 20W50. Also, ATF type "F" works great (Use it in my KX250)in 2 stroke trannies and is very inexpensive. Change often is the most important thing. Many trans fluids are dyed red.
  • brianandmell
Posted April 16, 2009 - 07:23 AM
thanks for the info, i just didn't want to mess something up.
  • DieselSJ
Posted April 16, 2009 - 08:46 AM
It is rumored that this is really just repackaged ATF, which does explain the red color. IDK if anyone has ever had it tested to see if that is true though.
  • brianandmell
Posted April 16, 2009 - 09:23 AM
But the main question is, is this a better oil than what i have been using and is it safe to use in his bike? We have a big weekend of riding and i just don't want to mess anything up.
  • SAPPERS
Posted April 16, 2009 - 10:00 AM
I'm not real sure of that exact oil. But save yourself some money, take it back and swing by the auto parts store and pick up 3 qts of Type F for the same price as the one factory stuff. At least we know this oil is proven and works. Do a search and you'll see.
Or read this caption
  • KDXKRIS
Posted April 16, 2009 - 12:14 PM
As stated above.......yes.......totally safe and I think you'll find the clutch will not drag as much as using 20W50 motor oil. Also as stated above....save some money and go get Walmart or any type F ATF.
  • cxcmoto
Posted April 16, 2009 - 12:32 PM
With that said, ATF has all the right components to work in a wet clutch/fricton environment. Many people use it successfully.
I think the most important thing is to change it regularly.
I've tried everything to fix this, please help. by UglyCasanova
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  33 replies
Traction Issues by TheHondaRidingKxOwner
  • Hot  52 replies
Are torque wrenches really necessary? by ChristianMX
  • Hot  28 replies
Help ! It refuses to idle...no matter what.. by UglyCasanova
  • Hot  36 replies
Not sure if my 2 stroke cylinder needs bored/replated etc by Jack wagon
Dirt Bike   Dirt Bike Technical Forums   Engineering and Technology
  • Hot  27 replies
