anyone know if a yfz450 carb will fit a yz426f
10 replies to this topic
  • keegan1014
Posted April 15, 2009 - 02:44 PM
looking to see if the yfz450 carb will fit on a 2001 yz426f
  • keegan1014
Posted April 15, 2009 - 02:47 PM
the part number is a little diff. and the yfz carb has
something called a carb switch (I think thats what they call it)
2 wire connector near the TPS
Posted April 15, 2009 - 03:14 PM
If you mean to say YFZ, as in the quad carb, you don't want it. It is emissions equipped, and will be a nuisance.
  • keegan1014
Posted April 16, 2009 - 07:15 AM
so where is the emissions equipped and will it fit?
is the emissions elec. or restriction in air flow, fuel delivery where ?
Posted April 16, 2009 - 07:46 AM
Jetting, air cut valve, capped pilot screw, needle with no grooves, etc.
You don't want it.
  • keegan1014
Posted April 16, 2009 - 04:08 PM
thank you SIR
the jetting is the same as on the yz426
165 main
45 pilot
needle on the fourth grove
sounds like even if the jetting was like you said a jet kit would fix 95% of it
it might not be th carb your thinking of the only diff.
is something called a carb. switch two wire deal
ive had both carbs apart as far as inside very close to the same
but again thanks.
  • erickdj
Posted April 16, 2009 - 04:13 PM
With time, patience, creativity, and determination, a lot of things can be accomplished. Sounds like the bike could be made to run with that carb.
  • keegan1014
Posted April 16, 2009 - 04:18 PM
I realy give thanks for all the help
but I dont understand the jetting is the same as the factory carb
maybe im thinking its a diff. carb then it is
Posted April 16, 2009 - 06:09 PM
The year model of YFZ was never specified. It could be I looked at later ones only.
  • keegan1014
Posted April 17, 2009 - 03:28 AM
this is the one here
http://fiche.ronayer...oup/CARBURETOR_
I know you know what your talking about
I just dont want to make a mustake
But I could just try it and see how it turns out
im waiting for some parts before I do it thou, and will post the how it goes.
  • keegan1014
Posted April 20, 2009 - 01:00 PM
any luck on this one guys
  • 10 replies
  • Hot  38 replies
  • 3 replies
