03 wr450
5 replies to this topic
  • cubby
Posted April 15, 2009 - 07:48 AM
I have a 03 wr450 and it has a gytr front brake lever on it. My ? is if I am pushing the bike and pull the lever the tire will lock up but if I'm on the bike and riding and go to stop no matter how hard I pull the lever the front tire will not lock up, is there any way of adjusting it to get more pressure. Thanks:thumbsup:
  • wartsnuff
Posted April 15, 2009 - 08:46 AM
is the handle contacting the bar?
if the answer is no.. i would change the front pads... glazed prehaps and not biting into the rotor.
otherwise if the lever is hitting the bar. then i would say bleed the brakes. see if there is air in the line.
cheers and good luck!
Warts
  • cubby
Posted April 15, 2009 - 09:46 AM
Thanks I will check to see if they are glazed
  • Krannie McKranface
Posted April 15, 2009 - 12:55 PM
Do you get low resistance on the lever? If you pump the lever does the resistance increase? If so, you need to bleed the system.
  • SamHard
Posted April 15, 2009 - 10:48 PM
you pushing the bike and you on a bike that is moving at a considerable rate have a huge difference in inertia. While most breaks WILL lock up if squeezed hard enough, perhaps you have a blessing as a locked front tire is an uncontrollable front tire........just a thought
  • cubby
Posted April 16, 2009 - 09:38 AM
Samhard, I hear you on that one but my friends 05 wr450 will lock up with him on it and I was just wondering why mine won't. No big deal it still works.
