Air Box Question on 2007 wr450f
4 replies to this topic
  • bruceal
Posted April 15, 2009 - 03:33 AM
What is the best way to modify the air box on a 2007 wr450f? I have jetted the bike and installed a fmf slip-on exhaust, but I am not sure about cutting holes in the plastic air box. I have removed the snorkels. Thank you.
  • stevenacarter77
Posted April 15, 2009 - 05:30 AM
did you take the snorkels base plate off of the air box ? also are you going to install a hi flow air cleaner like a uni ??
  • William1
Posted April 15, 2009 - 05:37 AM
Once the snorkle and retaining plate is removed, the plastic mounting rectangal can come out too, lift up the batter to see the mounting screws.
  • bruceal
Posted April 16, 2009 - 03:09 AM
OK, great I will give that a try.
  • WR450FGreg
Posted April 16, 2009 - 03:25 AM
I seem to remember Ballards (internationally renowned Australian enduro gurus) recommending three or four 20mm diameter holes be drilled in the bottom of the airbox after the snorkel was removed.
Greg
