Steering stem bearing question
3 replies to this topic
  • 426 NOOB
Posted April 14, 2009 - 03:49 PM
I took my steering stem appart and the top bearing had dirt on it but the bottom was fine. My question is, What is the part # for the metal insert that is in the neck of the frame that holds the top bearing in place (or from falling down in the tube), the top bearing, and the rubber coated race, that sits on top of the bearing that comes in contact with the spanner nut? Thanks I dont want to order the wrong pn and the microfiche for this is confusing.
This is for an 01 426
  • mitchicle
Posted April 14, 2009 - 05:22 PM
Are you talking about the race?
  • mitchicle
Posted April 14, 2009 - 05:28 PM
If i'm understanding your question correctly you will need:
BEARING (5JG5) 93332-00078-00
COVER,BALL RACE 2 (5JG5) 4EW-23416-00-00
WASHER,PLATE (5JG5) 90201-286K9-00
Hope this helps. :p
  • 426 NOOB
Posted April 14, 2009 - 05:50 PM
Hope this helps. :p
thank you very much. The pictures dont look anything like the actual parts so I couldnt figure out what parts were the right ones. this seems to be them. Thanks again
  • 0 replies
  • Hot  79 replies
  • 5 replies
  • Hot  36 replies
