Rear brake assembly not fitting on swingarm
1 reply to this topic
  • drfeelgood824
Posted April 13, 2009 - 05:59 PM
I picked the rear tire and caliper assembly used online, noted as a 99'
When i slid original rear rotor into the caliper assembly, the rotor didn't fit into the caliper fully and i was unable to slide the rear axel through the swing arm tire assembly. i replaced the rotor with a Tusk Stainless Steel Brake Rotor, Rear - 1999 Yamaha YZ400F .
Without the rotor, everything will fit together. Does anyone know for a fact if a 98 rotor is smaller then the 99 rotor? I don't wanna throw more $ out on something that might be the same. Thanx.
  • drfeelgood824
Posted April 14, 2009 - 12:50 PM
heads up....
I spoke with tech @ rockymountain mc, and the rotor diameters are as follows:
98 yz400f= approx. 8 5/8"
99 yz400f= approx. 9 5/16"
  • Hot  106 replies
Need help by Goforaride
  • Hot  68 replies
  • 9 replies
  • Hot  36 replies
