Noticed a couple things after my four day riding trip. i need some help
13 replies to this topic
  • Davos
Posted April 13, 2009 - 10:10 AM
My bike (08 yz450f) does not like to go slow. At none to quarter throttle the bike is either accelerating or totally off the power. This only happens when riding with the kids slowly, trying to maintain a steady low rpm for a long time. Would a heavier flywheel help with slow riding and hill climbs?
My bike runs and starts great, however i have noticed a little black soot on the inside of my pipe after each ride. Is this normal or am i rich?
Jetting is
main 168
pilot 42
leak 50
needle NFLP
Riding at 2200-3300 feet mostly
60F-90F
  • yz480doinwork
Posted April 13, 2009 - 10:15 AM
back when mine was stock i had a 148 main and a 45 pilot. but i was riding from 5000 to 11,000 feet. the joys of mountain riding a race bike!
  • TIG88
Posted April 13, 2009 - 12:06 PM
If you do alot of slow riding, a new sprocket(s) would help alot. A flywheel weight would compliment your new gearing. Id try gearing first though.
A little black soot is completely normal.
  • Davos
Posted April 13, 2009 - 01:24 PM
I thought gearing would help too, I went from a 49 rear to a 51. 1st gear is much lower and it really helped in the tight stuff and it made wheelies super easy. but the ride is still really jerky when giving it gas in the slow speed stuff. Im thinking a 11oz FWW will help me out alot. but i dont want to spend that money without knowing for sure.
Thanks for your replys guys
  • TIG88
Posted April 13, 2009 - 01:39 PM
If you dont like the FWW, sell it on ebay
  • Wiz636
Posted April 13, 2009 - 02:04 PM
YZ450's are full on race bikes and are not designed for and don't like to putt along smoothly at low throttle openings so anything you do (gearing, FWW) will only take a little bit of the edge off of it. As a matter of fact, gearing it lower might even exacerbate the issue by making the bike that much more snappier and responsive to slight twitches of the throttle from hitting bumps.
The best thing I have found for trying to maintain a slow, steady pace is a very light throttle hand.
  • rexbond007
Posted April 13, 2009 - 04:38 PM
125 hrs on the bike and still my best purchase i made was the GYTR Off Road Flywheel Weight , and went from stock 49 teeth to 51 rear sprocket. i did try a 50 tooth but it was not enough.
  • davcon
Posted April 14, 2009 - 06:26 AM
I have a similar problem while trying to go as slow and quiet as possible thru our neighborhood to the riding spot. Stock 08 YZ450. I thought it was a lean needle setting. Dropped the clip with no improvement. Wonder if a different needle would help?
  • wondermuscle
Posted April 14, 2009 - 06:55 AM
I agree with the FWW. I have the heavy GYTR and it makes a huge difference. If you plan on doing any moto I would go with the lighter of the two as the heavy one takes most of the snap away. PM me about the heavy one, I'll be doing some testing this weekend and may end up not liking it.
I would also reccomend going to a 165 main and a 45 pilot jet. I found the 42 to be a bit lean.
Russ
  • LAndrew
Posted April 14, 2009 - 07:41 AM
Who has some riding experience with the 1st GYTR option slightly heavier FWW ( Adds 4.83 oz. for an inertia mass of 4.9 kg-cm² (stock inertia mass=3.8 kg-cm²) 30%)
I got this as part of a deal with my Scotts damper and am about to put it on, just wanted to hear others ride reports with it.
  • Davos
Posted April 14, 2009 - 08:31 AM
I am pretty sure that putting the 51 tooth sprocket on made the problem slightly worse. However now i dont need to slip the clutch hardly at all when taking off. and that is worth the top end loss. (This really payed off this last trip, trying to climb up river beds with the 49 tooth would have me kicking her back to life all day!)
I agree about the 45 pilot as i am seeing that the 42 might be slightly lean. i think im going to install the stock needle. one clip richer and then go with all stock jets and then a 165(winter/Pismo trips) 160(summer) main because im running the FMF 4.1 titanium.
Thanks for all your help guys!! I dont think ill go with the FWW because i dont want to lose the snap my bike has!
Posted April 14, 2009 - 09:07 AM
IMO, it's barely noticeable, and will only show up as slight improvements in traction on loose surfaces. It will hurt nothing, though, and will help a little.
  • wondermuscle
Posted April 14, 2009 - 10:20 AM
Let us know what you think after you give it a ride or two. I'd be curious to hear a second ride report about the lighter one. Would you be interested in a swap if we aren't happy with the ones we have.
Gray - Thanks for the info too.
  • LAndrew
Posted April 14, 2009 - 12:45 PM
I will provide a report and if it does not do what I am looking for I will consider a swap.
We just got a freak snow blanket so it will be a week or so at least
  • Hot  47 replies
  • Hot  36 replies
  • Hot  50 replies
