starter mod
5 replies to this topic
  • valkyrie69
Posted April 12, 2009 - 12:41 PM
does anybody still have an 03 wr450 and did you have the 04 starter mod done if yes did u have any problems after the mod.thx
  • waydog
Posted April 18, 2009 - 02:22 AM
where did you get the parts for the 04 starter mod,, web site???
  • Thermos O flask
Posted April 18, 2009 - 04:29 AM
I did my mates '03wr450 and got the parts from "jp parts".The starter clutch is now worn out,not related to the '04 upgrade parts. Very easy to do.
http://www.wr450.com...inals/index.htm.
This will tell you what to do,BUT you don't have to take off the flywheel cover,just the small cover and fit the bush,then fit the new bits and smicky smack!
  • valkyrie69
Posted April 18, 2009 - 05:21 AM
not sure ,my dealer is getting them, 1 part is on back order, i think the cover i think its coming from japan should be another week ,,,hopefully, are you gettin the mod done too?
  • dmk75
Posted April 18, 2009 - 07:44 AM
So there is no need to remove the entire side cover as was done in this write up and the only parts needed as as follows:
04 Torque Limiter Part # 5TJ-15560-00-00 @ $204.99
04 Torque Limiter Cover Part # 5TJ-1549B-00-00 @ $28.99
04 Thrust washers (need 2) Part# 90201-105A8-00 @ $ 7.98 total
So in simple terms remove the small side cover, take out old Torque Limiter and bushings, put in new stuff, put on new side cover.
  • c9buff
Posted April 19, 2009 - 02:16 PM
Hey DMK75, what's the best way to take out the old bushings?
thanks,
buff
