07 YZf450 Oil pump removal
1 reply to this topic
  • Dan CRF250
Posted April 11, 2009 - 06:52 PM
im overhauling a 07 yzf450 that had a lower rod bearing blow, in turn clocking the oil pump with shavings and destroying it.. my problem is it looks like the outer "Rotor" on the pump is pressed into the right case, if so how do i remove it?
Posted April 11, 2009 - 08:06 PM
It's not pressed in. It sits in the bore in the case and should turn freely. It is probably jammed with debris from the incident. Try rocking/prying it out of place with something like a large pair of snap-ring pliers.
  • Hot  47 replies
  • 0 replies
  • Hot  30 replies
  • Hot  50 replies
  • On January 15, 2017
