Gray Need Help 01 426 hot cams
13 replies to this topic
  • pbviking
Posted April 11, 2009 - 10:36 AM
Hey Gray,
Can you please look at the pics and let me know if these cams are align correctly
ever since i put in the cams the bike does not want to start. once started.... it runs great....
Not sure what else to do from here ....the spark is good
http://farm4.static....a4aa910.jpg?v=0
http://farm4.static....4004eae.jpg?v=0
http://farm4.static....18e43f9.jpg?v=0
  • nashport_native
Posted April 11, 2009 - 11:24 AM
recheck your valves, sounds like one or more is to tight
  • pbviking
Posted April 11, 2009 - 11:30 AM
valves in spec
Posted April 11, 2009 - 12:35 PM
Timing looks fine.
  • pbviking
Posted April 11, 2009 - 03:52 PM
thanks
I guess something is wrong with the exhaust cam....:p
i put the original back in place and the bike runs fine
Posted April 11, 2009 - 05:46 PM
Describe how you attempt to start the bike with the auto-decomp cam.
  • pbviking
Posted April 12, 2009 - 07:25 AM
i tried using the old method...meaning on the compression push about 1 inch pass move the kick to the top and give it a good kick
I also tried kicking from the top on the compression stroke
I am wondering if something is wrong with the decomp exhaust cam
  • jimmydoorlocks
Posted April 12, 2009 - 08:04 AM
This might be helpful:
http://www.thumperta...ight=decomp cam
  • pbviking
Posted April 12, 2009 - 08:25 AM
Done that After repeated times and the bike not starting i had to pull the plug
  • jimmydoorlocks
Posted April 12, 2009 - 08:34 AM
Still no luck? That sucks. I just did the same mod (among other things) and am having some similar problems myself. Although, I think my problems are more due to something I missed that anything else. :p
I'd love to hear what you do to finally get it going.
Posted April 12, 2009 - 08:48 AM
That's what I thought. That's where most people make their mistake when they first move to AD cams. DO NOT push past compression. Push up against it, reset the lever to the top, and kick it right from that point.
  • pbviking
Posted April 12, 2009 - 09:12 AM
yep i tried both methods
every once in a while the bike would backfire
still no start....until i put the original cams back in
  • camman
Posted April 12, 2009 - 04:35 PM
Cams look like they are timed correctly in relation to each other but that does not mean they are correctly timed to the crank. Once you said it backfired made me suspicious. Also, did you check the lash – though this is rarely a problem as the base circles should be identical to the OEM? Make sure you are not hanging up a valve. I did not read all of the previous post so if these ideas have already been suggested – sorry!
  • pbviking
Posted April 12, 2009 - 05:50 PM
align TDC 2 methods.
1. timing marks
2. screw driver in the spark plug
  • Hot  38 replies
  • 10 replies
  • Hot  47 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
